Displays BGP configuration information.
N/A.
None.
The following command examples display various BGP configurations:
Output for show bgp for a VRF (PE-CE Protocol, RD and RT configured):
(virtual-router vrf-foo) # show bgp
Enabled : No OperStatus : Down
RouterId : 3.3.3.3 AS : 200
LocalPref : 100 MED : None
Always-Compare-MED : Disabled Aggregation : Disabled
Route Reflector : No RR ClusterId : 0
IGP Synchronization : Disabled New Community Format: Disabled
Routes from EBGP : 2 Routes from IBGP : 0
Routes redistributed: 1 Out Updates queued : 0
Fast Ext Fallover : Disabled MPLS LSP as Next-Hop: No
AS Disp Format : Asplain Maximum ECMP Paths : 1
ConfedId : 0 Multipath-Relax : Disabled
Confed Peers :
Networks : 2
ipv4-unicast 10.0.0.0/16 network-policy nwk.pol
ipv4-multicast 11.0.0.0/16 network-policy nwk.pol
Aggregate Networks : 2
ipv4-unicast 21.0.0.0/8 as-match advertise-policy: agg.pol
ipv4-multicast 22.0.0.0/8 as-set summary-only advertise-policy: agg.pol
Route Statistics:
Address family EBGP IBGP Redist.
ipv4-unicast 0 0 0
ipv4-multicast 0 0 0
Redistribute :
Address Family
Route Type Flags Priority Policy
ipv4-unicast
Direct EO 2048 None
ipv6-multicast
Direct EO 2048 None
Flags: (E) Export Enabled, (L) Export Operationally Off due to Low Memory,
(O) Export Operationally On
Advertise Inactive Routes:
ipv4-unicast : Disabled
ipv4-multicast : Disabled
ipv6-unicast : Disabled
ipv6-multicast : Disabled
ipv4-vxlan : Disabled
Output of show bgp for a VRF (PE-CE Protocol, RD and RT “not” configured):
# show bgp
ConfedId : 0 Outbound rt. filter : Enabled
Confed Peers :
Networks : 4
ipv6-unicast 2001::/64 network-pol nwk6.pol
ipv6-multicast 2001::/64 network-pol nwk6.pol
Aggregate Networks : 4
ipv6-unicast 2003::/64 as-match advertise-policy: agg6.pol
ipv6-multicast 2004::/64 as-set advertise-policy: agg6.pol
Route Statistics:
ipv4-unicast 0 0 0
ipv6-unicast 0 0 0
ipv6-multicast 0 0 0
Redistribute:
Address Family
ipv4-unicast
Direct EO 2048 None
ipv6-multicast
Direct EO 2048 None
If BGP is added as a protocol inside a heavy-weight VR, normal BGP peering applies with the addition of vpnv4 address family support:
# show bgp
Confed Peers :
Networks : 4
nwk6.pol
Route Statistics:
ipv4-unicast 0 0 0
vpnv4 0 0 0
ipv6-unicast 0 0 0
Redistribute:
ipv4 Admin Operational Shutdown Policy
unicast Status Status Priority
Direct Disabled Down 2048 None
Static Disabled Down 2048 None
RIP Disabled Down 2048 None
BlackHole Disabled Down 2048 None
OSPFIntra Disabled Down 2048 None
OSPFInter Disabled Down 2048 None
OSPFExt1 Disabled Down 2048 None
OSPFExt2 Disabled Down 2048 None
ISISL1 Disabled Down 2048 None
ISISL2 Disabled Down 2048 None
ISISL1Ext Disabled Down 2048 None
ISISL2Ext Disabled Down 2048 None
multicast Status Status Priority
ipv6 Admin Operational Shutdown Policy
Ripng Disabled Down 2048 None
Ospfv3-intra Disabled Down 2048 None
Ospfv3-inter Disabled Down 2048 None
Ospfv3-extern1 Disabled Down 2048 None
Ospfv3-extern2 Disabled Down 2048 None
This command was modified in Extreme ExtremeXOS 15.3 to reflect its operation in VRs and VRFs.
Support for IPv4 VXLAN was added in ExtremeXOS 22.3.
Support for BGP multipath-relax was added in ExtremeXOS 22.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
